how to create Drawing symbols with variable text
  • Thread starter Thread starter david.connor@hbh.com.au
  • Start date Start date
D
Guest
We are trying to do some drawings for a client (which will end up in Acad) which uses non standard view, section and detail title tags and we want to create drawing symbols that we can place and modify the text with out exploding the symbol
Create some text in the symbol, with a backslash before and after, eg:
\note
This will allow you to vary the text contained in the note.
You may also add a list of values (and limit to the list if you want).
Ed
Ed
thanks that is what we were after
