Z
Zaki
Guest
Hi Guys
we used to create a thread end like this in proe is rotational blend command. But how I make it in Catia I am sharing with you and need your opinion as well as another approaches.
just create a shaft feature of any dia and make a sketch on yz plane like below on diameter surface. this is for starting point of helix.
Now go to generative shape design and create a helix on lower point of sketch2. My perameters are 4 mm pitch and 20 mm height (5 full turns).
now create a sketch on yz plane and lower point of sketch2 or start point of helix. triangle is for thread profile and left portion is to close the thread section properly.
Edited by: Zaki
Edited by: Zaki
