How to create a drawing for assembly mechanism
  • Thread starter Thread starter Arul
  • Start date Start date
A
Arul
Guest
For example I got a cylinder and piston assembled together using a connections.I want to create a drawing to show both
the views closed and open positions in such a way that to mention the stroke length.
I don't want to rename the assembly&make the two views.
Is there any betterway to do that...
Thanks in advance.
Arul
In the mechanism mode, there's an option to take a snapshot & use it in drawings...
In drawing mode, change the view type to exploded and pick the state you saved in Mechanism. Each mechanism location is stored like an exploded state.
Yes,It works fine.
