how to creat diameter dimension?
  • Thread starter Thread starter victory
  • Start date Start date
V
victory
Guest
when i creat a dimension of circle, there always show in radius
dimension ,but i want to show in diameter dimension,how can i do ?
Have you tried double clicking the circle?
I just try as your reply, but no success!
I just try as your reply, but no cuccess!
As especial says - click twice on the circle before middle-clicking to place the dimension.
If the radius dim is defined in the model, redefine the section - remove the radius & add a diameter dim...
You need a center line for the diameter; click edge, centerline,edge in the model. If it shows a diameter in the model in sketcher then it should display a diameter in the drawing.
jperkins
