Apr 18, 2003 #1 S simo Guest somebody know if it is possible to copy some features from different models (.prt)? thank you Simo
Apr 18, 2003 Thread starter #2 X xcad Guest feature > create > datasharing > copy geom > open your model , select features, surfaces, curves, and import them in your model (depended or not) it works only if you have AAX licence xcad
Apr 18, 2003 Thread starter #3 G gurveen Guest another way is to make UDF library Feature>UDF library you can use dependent or independent as per your requirement
Apr 18, 2003 Thread starter #6 D dougr Guest Check the following link: http://ptc-mss.com/Tutorial/shared data2.pdf This summarizes all the available techniques in Pro/E so all the above are covered also (with the exception of the udf idea)...
