How to check if a length is in increments of 0.5 CATIA V5 ADVISOR
eduardopinto07
Automotive
Hello colleagues,
I am trying to create a check using CATIA V5 knowledgeware advisor.
I have a length parameter and would like to check if it is in 0.5 increments.
Ex
100-true
102.5-true
102.3-false
100.1-false
305-true
I don't need macros(VB, VBA, CATScripts, etc...)
I need in EKL using advisor
Any help will be really appreciated!
Best regards
Eduardo
since the mod function in KWA only accepts integers, I looked into alternative representation of the modulo function
(see e.g. wikipedia "modulo operation"
implement below line as a check:
Length.1/1mm-0.5*floor(Length.1/1mm/0.5)==0
or prescribe that the length parameter is in increments of 0.5 (right click, change step, new value)
regards,
LWolf
Hi LWolf,
Thanks a lot for your comment!
Yes, I thought the same...in java you can use something like (Num % 0.5==0)...done.....in CATIA the Mod(Real, Integer)...no way...
Thanks a lot!
try multiplying the length by 10 and checking that it is in increments of 5 instead of 0.5?
(Length.1*10)/10mm-5*floor((Length.1*10)/1mm/0.5)==0
or multiply by 2 and compare with the int... like : int(length.1 /.5mm) - (length.1 /.5mm) ==0
Eric N.
