how to calculate volume in catia 5
  • Thread starter Thread starter mikro89
  • Start date Start date
M
mikro89
Guest
please help me
use the Measure Inertia tool
Secure correct weight
Sometimes it happens imported parts get wrong information about weight. Ex imported step-files for pnematic cylinders and clamps.
Well..
-Add some material and doubleclick on that.
-Tab "Feature Properties" name it whatever you want.
-Tab "Analysis" field "Density", type 100kg_m3
-Apply and OK
-Messure Inertia and copy information in field "Mass"
Open Excel
cell value
1:1 = 100
1:2 = Type in the value that you find in "Mass"
2:3 = The true weigth for the product, often found in vendors productcatalog.
2:4 = =R[-3]C[-1]*R[-2]C/R[-2]C[-1]
-Copy the result in 2:4
-Doubleclick the material.
-Tab "Analysis" field "Density", type in the value from excel ex.. [TABLE="width: 87"]
[TR]
[TD="align: right"]5753,424658kg_m3[/TD]
[/TR]
[/TABLE]
-Apply and OK
-Messure Inertia and you will find the correct weight for the product, in field "Mass".
