how to calc flange thk(B16.5 and Appendix 2
AliGrailly
72
1-How to calc welding neck flange thickness asme b16.5 Example for 3" is 27mm min
2-As per appendix 2 for calculation of blind flange thk attached by bolting needs total bolt data and b .. where can i find this data about flange 32" ? is there a catalogue or any site to mention all
could someone give me an example?
You can't calculate this - it is simply stated I think. A section or page or snapshot would make it clearer.
Which appendix 2? ASME B 16.5 or ASME VIII?
Can you expand your question a bit as it's quite confusing to me.
I just know
1-how to get flange thickness in asme b16.5 for example for wn flg 3 " class 300 min thk or tf is 27mm
2-Asme Viii Appendix2 Describe the formula for Calculatiing blind flg thickness eighter inserting it between two flangs or blind flg with bolts ... now
this is my data and my question is how to calc w , N ( catalogue for width or website give this data w,n for flanges)
3" Flange
c=0.3
P=1.53 kg/cm2
S=1407.21 kg/cm2
E=1
hg=2.92
C=16.8cm
raised faces diameter=12.7cm
width N=2.435cm
G=10.96cm
GOD,GID=12.7,7.83
W? kg
Ali,
Your question 1 - You simply look up the table, in your example Table 11. You can't and shouldn't be calculating this. Just accept it.
The ASME B 16.5 ratings and sizes come, in the main part, from 100+ years of operating practice and experience and an occasional agreement to e.g raise Pressure and temp operating numbers or modify dimensions.
Question 2
If you want to for some reason design your own flange, then yes, use Appendix 2, but it is well known that flanges built to ASME B 16.5 often "fail" or are thinner / smaller than those designed to Appendix II of ASME VIII.
I've got lost as to what you're trying to do as opposed to simply using a blind flange from ASME B 16.47? Or MSS SP-44
A spade or blank is different to a blind flange - what are you actually trying to do? Note most blanks or spades only go to 24".
About question 2 i need w value and its calculation
Volume x density?
