how to avoid shell problem
  • Thread starter Thread starter pintu
  • Start date Start date
P
pintu
Guest
i wil be become very glad if any body will tell me the limitataion of for shelling a part.
thankx
pintu_33@hotmail.com.
what kind of problem do you have?
maybe you have to modificate part accuracy?
set up - accuracy
the smaller value the thinner wall is possible (but also slower to regenerate)
Analysis > surface analysis > radius > select the surface > compute
and observe the Min. inside radius, this value is your limit to your shell feature
Smallest radius and smallest edge will give you the minimum thick.
If a thicker wall is needed, you can try creating the inside geometry and thickening to the outside. This generally makes shell features more robust since radii that grow in diameter don't disappear when the thickness grows.
do min radius analysis to check the offset value you can achieve. thats the shell thickness you can give.
