P
prdecina
Guest
Sir/Mam:
I currently designing a simple motor gear with a driven gear attached.. i used the default gears at the toolbox and make a Spur gear with a 14 teeth.. But when i make a Internal Spur gear the minimum teeth is just 24 .. so now i ant math the teeth of both gear together..
i tough that the internal spur gear can adopt to the standard spur gear the toolbox.
Is there any easy way to make it rather than using a spline??
