CorporalToe
- Mar 9, 2024
- 45
Hello, I am trying to make a flat roof and sloped roof diaphragm.
For the flat roof I think I did it right. I made a area thin shell element, I am using CLT wood for the roof, so I set the material as wood. I made the m11, m22, m12, v13, v23 modifiers 0.0001, also made the mass and weight 0, as I will manually add in the self weight loads. I added a diaphragm constraint to the joints of the diaphragm and ensured that the frame elements have auto mesh enabled. I think this is the correct way to do it but if you have some insight or recommendations please let me know. Btw I am trying to model a rigid diaphragm.
For sloped I do not know what to do, I have a 30 degree slope with a ridge beam and 1 beam on either side of the roof. I want it to act as a diaphragm, but my previous method is not working.
I have 2 questions:
Was by method for diaphragm model correct for the flat roof?
How do I model a sloped roof diaphragm?
I have 2 questions:
