I am trying to calculate the stiffness of a custom screw using K = EA/L, but while specifying the length, I'm having a hard time visualizing how a fastener elongates along its length when preloaded into various plate configurations.
As a simple example, suppose you have two plates that are 0.5 inches thick each. Both plates have unthreaded through holes. A bolt is installed and tightened with a nut. It seems straightforward that the fastener will elongate only over 1 inch.
Now suppose both holes are tapped and no nut is used. It seems the compressive deflection of the plate threads will fight against the tensile deflection of the bolt threads. Do the threads just plastically deform or does the system just bind up before you can generate appreciable preload? Or something else? What effective length would be used to calculate the bolt stiffness here?
Now suppose the top plate is a through hole and the bottom plate tapped. Same questions here. Does it bind up a little in the bottom plate? What is the effective length for the stiffness calculation? Does the fastener within the tapped hole portion elongate? Is this elongation non-uniform along the fastener? I know that's a lot of questions, but these are just all kind of floating around in my mind and I can't resolve them.
Cameron
Cameron
