How do I create macros in UG/NX4?
  • Thread starter Thread starter gshock
  • Start date Start date
G
gshock
Guest
I'm new to the forum, and I posted this same question earlier, but it doesn't show up in the forum.
I'm trying to create some macros in UG/NX4. I'm very new to UG, but not to 3D modeling. I'm proficient, but no expert. Where do I start?
Thanks in advance for the help.
Best regards,
-gshock
Macros in UGNX4
Hi there,
Goto Tools>macro>Start record and choose a location for your macro file.
Now execute your command, in this case you will have to goto Analysis>Distance, select the Projected Distance option and select X as your vector, at this stage goto Tools>Macro>User Entry and choose the two entities you want measure. Now goto Tools>macro>Stop Record.
Your macro file is ready to use. You can check by Tools>Macro>Playback choose the macro file you just created. Every time this will allow you to choose two entities but always will give a distance in X direction.
Hope i was clear enough.
