How can I insert the entire family table into the drawing?
  • Thread starter Thread starter mjc6727
  • Start date Start date
M
mjc6727
Guest
I am creating a generic drawing for an o-ring with 37 instances, and I wish to show the entire family table in the drawing. I recall that this can be done in Pro/E2000i, but I can't figure out how to do it in Pro/E 2001.
Any help would be appreciated!
Do you want to create a table in the drawing that shows all the instances?
eServ,
Yes I do want the table to show all the instances. Specifically, I have currently 37 instances, with 4 dimension columns in the family table, and I want the drawing to show the entire family table (with 5 columns and 37 rows,column 1: instance name
column 2: dimension 1, column 3:dimension 2, etc).
I believe in Pro/E 2000i you could just click INSERT-FAMILY TABLE in the drawing menu, but I can not find it in 2001.
mjc, shoot me an email at kalexander@ptc.com and I'll shoot you a Pro/REPORT table (.tbl file) that will do exactly what you are asking. As long as I can remember, inserting a table has been the way to achieve what you are asking.
later
Did you try creating a table, setting the Repeat Region, Enter Text, and selecting Report Sym, Fam, Inst, Name??? Have you tried going that route?
Can anyone please let me know how to insert a family table in a ProE drawing asap?
Thank You.
Deepika
Look at this for general method:
[url]http://www.proengineertips.com/drawing/tutorial-create-bom-t able-in-pro-e-detailing-3.html[/url]
The parameters you will use for family table would be fam.. inst.. name as Eserv suggested, then fam.. inst.. param.. value.. which I hope you have named in a way so you can find it...
Here a 2 quick tutorial videos on Repeat Regions with Family Tables:
repeat_region_family_table_01.swf 10.5 MB SWF Video
http://santangelo-eng.com/proe_tuts/repeat_region_family_tab le_01.swf
repeat_region_specific_filter.swf 21.5 MB SWF Video
http://santangelo-eng.com/proe_tuts/repeat_region_specific_f ilter.swf
Cheers,
James
Thank You.
Deepika
