How can I change the default BOM?
  • Thread starter Thread starter lasala
  • Start date Start date
L
lasala
Guest
Hi!... I'd like to add some parameters to the BOM list, I know that I can change it, but I don't know how to do it... Somebody can help me?
Thanks...
Are you using Pro/REPORT Formats or Drawing Tables with Report Fields?
You should also consider using p-BOM - may get what you are looking for faster.
http://www.buydesignautomation.com
Dave
- To add more parameters into a BOM, use Table > Enter Text > Report Sym.
- Then select a cell in the repeat region.
- Then pick which parameters to include, for example:
Index: rpt.index
Quantity: rpt.qty
Custom parameter material:
Click asm, then mbr, then User Defined, then enter material:
asm.mbr.material
Add other parameters in the same way.
Ed
Use bom_format option to change from default BOM to user defined one.
You need to create a simple text file and place it in your ProE directory.
Change bom_format and browse to the file you have created.
Info about format of the file you can find in ProE Help.
Coolbe
