N
NC12
Guest
Anyone can recommend a best practice on creating hose assembly in Creo?
We'd like to the same part number (in this case asm p/n), whereby the end fittings are the same but the hose part is different in routing. So from the asm level standpoint it's the same p/n in parts list, but the same hose asm can be applied to different area with same hose length but different hose routings. Would be nice if the .prt is also the same.
