iengineerstuff
- Aug 4, 2021
- 11
I have been doing quite a bit of research on Cold joints in concrete beams, however, I have a more particular problem than i found that can be addressed in some of the forums. Looking for a second opinion.
I have a concrete beam that is torsion controlled. There is a 5' cantilevered balcony, that was supposed to be poured monolithically as noted on my plan. The contractor went rogue and poured the bottom portion of the beam across the full span. Currently leaving the top portion exposed and the cantilever slab unpoured. I was on site by chance last week and noticed the glaring issue.. Now the contractor is hoping he can proceed with as is, rather than tearing out the beam and having to repour the section.
Here is where I stand:
Because the design is torsion controlled, I have concerns that my overall torsional section is going to be reduced by half, unless there is enough shear friction at the cold joint to allow all stresses to develop across the entire beam section. So, there has to be enough shear friction to resist the combined effects of torsional and shear stresses across the depth of the beam, as well as, maximum torsion across the width of the beam.
Considering, this issue was not approved prior to pouring, my gut feeling is to have them tear it out. I am not comfortable with the design, and I have yet to start crunching numbers. Also any reinforcement that needs to be added will be post-installed which leaves the potential for damaging the beam. Which I cannot guarantee won't happen.
Does anyone have any advice on this? Has anyone been in a similar situation with shear friction for a torsion controlled beam?
