dik
- Apr 13, 2001
- 26,053
I have a simple home theatre setup... I have a cable modem in for internet, an A/V Receiver and a TV set.
Is it best to connect the cable modem directly to the TV or to the A/V reciever. From there, I can connect to the other component. I can use a CAT 5 cable and then an HDMI cable to the end component. There is surround sound with the setup... I will be connecting a couple of 8TB HDD to the USB ports on the TV.
Dik
Dik
