R
RJParkes
Guest
I have discovered that whichever option I use to mirror holes, I usually have to go into the mirrored hole set and flip the direction on the 1st hole of a pattern in order to get the holes to show in the structure. Before this the holes show when the pattern is selected but they do not appear in the structure.
Ihave also found that when using a table to pattern holes in an assembly made up from seperate parts usually results in the holes being highlighted when selected but not actually showing in the structure.
Has anyone experienced similar events or am I doing something wrong.
