bugbus
- Aug 14, 2018
- 533
I have some square hollow section posts that are situated outside and exposed to rain and occasional flood waters.
The posts are entirely sealed apart from a small galvanising vent/drain hole near the top. This hole is on the vertical face of the post and drilled in a horizontal direction prior to galvanising. There are larger vent/drain holes through the baseplate also for galvanising purposes, but since the baseplate sits on a grout pad these no longer provide any drainage to the post if water were to get inside.
The client is concerned that the post could fill up with water, which could create a corrosion problem inside. Note that the inside of the post is well galvanised.
Would it be best to try to plug the small hole at the top of the post to prevent any water getting in in the first place, or alternatively drill an additional drain hole at the base of the post and keep both holes open to allow the water to drain out and dry up?
My feeling is that the first option is futile, and water will find a way in no matter how well it is plugged. Second option feels better to me, with appropriate repair of the new holes by zinc rich paint protection.
