T
TMPENG
Guest
I'm trying to use the hole table in a drawing. You can choose to make the hole diameter as a column in the table. However, the column is populated with the hole type instead of the hole note. For example, if when modeling I used the hole table to create a 1/4-20 shank/thru hole, creo will create a .281 dia hole. When I place the hole table in the drawing, instead of listing the hole as .281 dia, it shows 1/4-20. Is there a way to make it actually display the hole note? I have come up with many work arounds (i.e. manually typing, copy/paste the hole note, etc..), but ultimately, this seems like something that should be doable.
Matt
Matt
