Hole Patterns
  • Thread starter Thread starter Raed Allam
  • Start date Start date
R
Raed Allam
Guest
Hello Im a beginner to Creo Im currently using student version and having some issues with patterns.
I designed a pulley with a inclined bore (6.38 in large diameter 6 in small diameter, Length of bore = 6.38 in). I made a socket cap screw hole along the wall of the bore using project and sweep functions. I need another two holes with the same dimensions but one is -120 degrees away from it and the other is +128 degrees. I can use the pattern function only once on the part. thus i can do either the -120 degrees or +128 degrees how can i do the third.
I dont want to go throught drawing the holes again its really complicated. any ideas?
Use a table driven pattern.
