Hinge Mechanism in Assembly
  • Thread starter Thread starter kerklein2
  • Start date Start date
K
kerklein2
Guest
I am new to Pro/E and I just decided to take a look at mechanisms today. I have a hinge model that I have created and a servo to turn it 90 degrees when the Analysis is run. I have attached this hinge to two parts in an assembly to open and close the door, but when I try to run the analysis, it says that the analysis does not belong to the current model. Do I have to create a new one to make it work like I want? Is there an easier method to create a rotating hinge assembly with a door? Thanks for all replies.
Edited by: kerklein2
Also, when I switch to mechanism in the larger assembly, I get a warning that my connection is not defined from two bodies and if I continue, they will be suppressed.
Another thing I just noticed. When I open the hinge and edit definition on the movable piece of the hing, it says connection definition complete, but the same part when placed in a larger assembly says connection definition not complete.
Ok, now I seem to have got the connection right and am in mechanism in the larger assembly. I tried to create an analysis but it wont run, it just fails. I think the problem may be that all of the parts are in the ground but I'm not sure and I can't figure out how to change it.
Hi
Shaun,
Would it be possible for you to post your assembly?
Maybe I'll have time to take a look at it.
I would, but I believe I got it working the way I want it yesterday. I never got an animation or an analysis, but I set limits on the joint and can just open and close manually, which is probably the easiest thing anyway.
