High pressure High temperature Solenoid Valve
Ahmed Zeid
9
Hello all,
I am working on a project where i need to control the flow of a hot Nitrogen line (300C) at a pressure of 7000 psi. I need to be able to control it electronically. However, i couldn't find a solenoid valve with these specifications. If someone knows a company that sells such valves please let me know.
I am also open for other suggestions regarding the valve type just in case solenoids are not most suited type for the job.
Thank you,
Ahmed Zeid
A hot valve like that will use a remote solenoid valve to control a nitrogen or air pilot line to actuate the hot valve.
Solenoid implies on/off.
"Control" implies a modulating action.
Which one is it.
Also what sort of size are we talking here?
Thanks for your replies. I am talking about a solenoid valve as in on-off. Pipe size is half an inch external diameter, 1/4 inch internal diameter.
You need an air actuated valve to do this, using a solenoid valve to operate the air actuator. You will not find a solenoid valve for such a service.
The highest temp solenoid valve I see on the net is 250degC. Can you install this solenoid valve upstream of the nitrogen heater instead ?
Like you mentioned, there were no such valves on the internet. I couldn't find any. Unfortunately, I can't place the valve elsewhere other than the pipeline itself.
I see a lot of replies talking about a pneumatic valve where the air intake is controlled by a solenoid valve. I start looking into that.
Thank you all for your replies.
