Diametrix
Aerospace
- Jan 31, 2023
- 54
I know you can use a square hole as a datum feature - put a single dimensions with a square symbol and attach a datum symbol to it. Can you do the same for other geometries as well? With the square you define two planes of symmetry which form an axis at their intersection. With other geometries they either form multiple axes or they don't form a plane at all (like in a case of a triangular hole). I understand the intent here with the gauge pin used to establish the datum, but I'm not sure that it jibes with the standard.
