Help
  • Thread starter Thread starter Diab
  • Start date Start date
D
Diab
Guest
Hoping all of you doing well
I have a solid body created from thickening a surface. The x,y, and z ranges for this body are from [0,1]. Now I want to create a complementary cube that fills the spaces in that domain. I want to set two different materials for the cube and the solid body. I tried the normal extrusion command, the software did the extrusion through the solid body ( so did not work with what I want).
This is the link for the part https://dl.dropboxusercontent.com/u/...6/Part1.SLDPRT
Any suggestion and any help are appreciated
Thank you in advance
Regards Diab
