M
moner
Guest
Hey everyone. This is my first post here, but I have lurked for years. I cant even begin to tell everyone how much I have learned from the forum here.
Ok, now that is out of the way, I need some help with a Mechanism job I have been given.
I have this simplified assembly fixture. It has a threaded shaft with a custom nut that has a square groove in it that rides along the flange on the base that keeps the nut from rotating. So, as the motor rotates fore and aft, the nut will move back and forth.
I have the nut and threaded shaft using a slot connection, but this is still inadequate. I cant figure what additional connections I will need to get this to work properly. I cant get the slider connection to work. I must be missing something.
I am now officially frustrated with this... any help would be greatly appreciated.
Ramon-
Ramon-
