Help with MDX !!
  • Thread starter Thread starter xcad
  • Start date Start date
X
xcad
Guest
Hello Pro/E users
I have a question that refers to MDX (Mechanism Design Extension) of Pro/E.
How is it possible to make two gears work together ;
I try to use the Model, Cam Follower connection and select the surfaces of the two gears but nothing works properly.
As a second try, I design the gears without the tooth, and using again the Model, Cam Follower connection it works with the drag option but when I put a servo motor to the mechanism nothing works properly again.
What am I doing wrong ; Is there a special way to make two gears work together ;
Thanx for ur time
If anyone have a good site that has valuable information about MDX, that would be very useful
Thanks my friend
I appreciate your help
Karavasilis V. Christos
