Help to input material ABS-M30 in Solidworks.
  • Thread starter Thread starter Aleksandar-
  • Start date Start date
A
Aleksandar-
Guest
Hi.
I need the material properties parameters for ABS-M30 plastic.
for that I managed to find a pdf in attached, but that data about that material can't be used directly in solidworks, does anyone know maybe the formulas by which I can convert parameters from pdf to parameters suitable for solidworks simulation? Is there somewhere to download the finished sldmat file?
Need to somehow convert the data from the pdf to the appropriate data required here: (as image)
