help needed creating surface
  • Thread starter Thread starter minicorrado
  • Start date Start date
M
minicorrado
Guest
I have a part i'm re-modelingin pro e 2001, the part was created in solidworks.i don't know how to recreate one of the surfaces..it was created in solidworks by a face removal command...where by it just joins the surfaces either side of the face that was removed...the pdf shows the surface i am trying to create.2005-04-06_125548_grille.zip
thanks
Matt
Edited by: minicorrado
You might stand a better chance of getting some help if you'll post a model. I couldn't really tell much from looking at the pdf.
have you got any of the crossections?, do you know what defines that curvature?
no i don't the curvature was created by the "remove face feature" in solidworks
here is a zip file of what i have so far i'm tring to do half the grill then i'll mirror it.
as you can see i'm having trouble where the parabolic surface meets the surface i created..the design call for the parabolic feature to be visable..but not a hard edge...any ideas?
Matt
2005-04-07_160124_3374a103.prt.zip
is this something likewhat you are looking for
unfortunately I dont know what the remove face feature in SW is..
2005-04-07_161834_3374a103_style_test.prt.zip
there is no tangency at the moment, but very easy to put in...
I used ISDX to create the surface.
James
or maybe this one?
2005-04-07_165719_3374a103_style_test2.prt.zip
again not full tangency.. but I dont really understand what yo uare looking for!
James
that looks very close to what i am after
how do i do that?
i'm using 2001
thanks
Matt
James
can't open the file you zipped
what version are you using
no tangency with the other surfaces
thanks
Matt
I used the interactive surfacing design extension, ISDX. yo ucould use pro surface also..
I'm using wildfire 2.0 unfortunately..
here is a .neu file 2001 shoud open it but it didn't convert too well and it is a dumb model
sorry,
2005-04-07_172049_3374a103_test.neu.zip
thanks james
on the right track...i was able to open it...close to what i want...but i don't want
the tangency...how do i do it in 2001?..i have the surface module
thanks again.....matt
this is exactly what i want to recreate without referencing the import feature. i want to be able to manipulate the the grill for other applications,thats why i can't just use the the dumb model.
thx
Matt
2005-04-07_173725_grille.prt.zip
build you curves and since you have style (isdx), create your surfces in that, I would probably do the chamfers after the model was built..
have you got the solid works model?
i do but it's in 2005 and the version i have is too old
here it is
thx
2005-04-07_175158_Grille.zip
do i have isdx???
havent got Sw 2005, only 2004 :(
you can see if you have isdx (otherwise known as style) by simply clicking on help/technical support info,
a window then appears, scrool down to "Configured Option Modules"and this shows you what modules you have installed..
if you have ISDX you should see Interactive_Surface_Design
Thanks James i'll check on monday
cheers and have a great weekend?
Matt
Hi minicorrado
why u making so hassles??? just go to boundry surface and make like this
Actually in wild fire 2 its extremely easy to create boundry surface even extreme complex but this could be created easily in 2001. Why you make it half and again mirror it???
ZakiView attachment 827
James,
I do not have interative surface
dave,
thank you very much
zaki,
i tried to do the part in one shot but i ended up with a ver bizarre surface as a result
thx
Matt
2005-04-10_134907_2005-04-10_3374a103_prt.zip
is there a way to flatten out the surface where the 2 curves that define the suface meet?
there is a raised peak origionating from the intersection of the two curves, i'd like to smooth it out
thx
Matt
p.s.
thanks Zaki, i tried your method aswell it is close to what im looking for, but daves method is closer,thanks again
