B
Bhuvan Lakshmn
Guest
Could anyone please help me in animation in creo parametric 3.0??
Details: as the picture above i have attached here,
Parts: 2 gears and 1 part (rod)
Gear ratio:1:1
Gear1 : is fixed
Gear 2 : is mounted above the Gear 1 (centre distance is 30 mm)
Rod: alone rotates along the centre axis and it connected to gear 2. in order to control the motion, Gear 2 revolves as it mounted on the gear1 and gear 2 revolves because it connected to rod on the top
i would like to animate: If i give the force to rod (i dont know how to assemble and animate the rod) as i shown in the picture the gear 2 should rotate along with the rod and motion along gear 1
Gear ratio:1:1
Gear1 : is fixed
