Help making Stress Analysis
  • Thread starter Thread starter Haim1404
  • Start date Start date
H
Haim1404
Guest
Hello everyone,
I'm pretty new to SolidWorks and learning every day.
For my project, I need to build a tower that is composed of several floors and each floor is built with the same geometric form. (as seen in the attached file)
Each form is built from popsicles (lets say balsa wood), that are connected to each other with Split pins (in the flat parts) and glue (in the angles)
How do you make a static stress analysis that will test how much load the structure will be able to hold and if it possible - to find the broken vector.
in addition, is there any way to simulate glue parts?
Appreciate any help!
