HELP!! How to connect Truss element to 3d body
As you can see I hope, it is the same problem as before (these nodes are on truss elements most likely).
Just use one single element with no compression.
OK you do not understand what the problems are here, what I am saying, and how to resolve this.
I am not going to teach you FEA here (it is of course good to know about FEA when undertaking such a complex task), so the most important thing is to understand that a series of connected truss elements are a chain-link and thus singular (instable, there is not enough stiffness generated in order to solve this problem). So for every series/chain of interconnected truss elements, needs to be a single truss element instead.
So whatever the trusses represent, say a tendon, then each tendon should then consist of a single truss element (a single finite element) with no compression property. So when you mesh, use a coarse mesh size on the tendons so you get only one truss finite element per tendon.
I finally understand what you mean by one single element, now it works.
Thank you so much and i am sorry.
Glad to hear that you have managed.
Happy to help, so no worries.
PS:
There is a dedicated ABAQUS eng tips forum, where you can post ABAQUS related questions. You might get more response there in the future.
