Genosphere
Student
Hello all, this is my first post here so be gentle. Currently enrolled in an Electrical Engineering program and finally finishing up next year. I have 7 years of avionic and airframe experience in the aerospace industry and more hours around automotive junk. I have worked plenty with coding, CAD design, and PCB board design. I'm not a idiot, but some times I need to warm my brain up like an old vacuum tube.
Anyway,
I'm looking for some direction on how to go about the following project. I am suppose to find two motors(just data not buy them) from online to use as references, which I am suppose to determine which of the two is best suited at the end of report(and why). I am not sure how to go about this, I am not looking for an exact answer per say, but rather some direction on how this should be presented with formulas and data. I have done a Design Report in another class, but not sure if that will fit this professor's "criteria."
I was not given any sort of references, examples, or rubric so I am at a bit of a loss on how its should be laid out, organized, and how the math would/should be expressed. So any help to get me started and guide me along the process would be great.
So what I know right now is by motor starting he's talking about how the coils or stators are wired. This article shows the main methods from what I see. 4160 @ 800 is specific and a very real world size motor rating. An PF(power factor) is going to play a critical role here as it usually does.
Again, I'm not looking for an actual answer, but guidance and some explanation to help me learn how one goes about figuring out a "real world" problem like this. Learning how to figure this out is the goal here.
Geno
p.s.(This class has been all over the place and an absolute nightmare in terms of organization and consistency, which is a shame since I was looking forward to electrical power, so this info from the email below is all I have to go off of.)
~~~~The Project Info~~~~~
You are the utility with an end customer who has a 4160V motor that they need to start. You must list advantages and disadvantages of each type of motor starting. Determine the best solution and give detailed design for the motor starting. The customer will be at the end of the line 12.47kV with 1000 Amperes of fault current available.
The customer has an 800 hp motor, LRC = 6 Times FLA, FLA = 1kVA=1HP. Must calculate FLA of the motor and give recommendations on how the motor should be started with detailed design. You must calculate the transformer rating as well.
Include the following: System problem, Motor starting types with advantages and disadvantages of each, Conclusion for each and detailed recommendations with design.
Anyway,
Geno
