helical sweep trajectory
  • Thread starter Thread starter Lambrusco75
  • Start date Start date
L
Lambrusco75
Guest
the start point of the trajectory is on the side instead of the centerline. what did I do worng?...I selected the normal to traj key.
can u explain more your problem? or put one picture
You can change your start point when sketching your trajectory. Select the point where you want the start point to be, then right-click and select Start Point.
