helical spring with no. of turns??
  • Thread starter Thread starter Vinom
  • Start date Start date
V
Vinom
Guest
I have some problem in modelling a helical spring Which is Square ended..
Here i have total no. of coils, I.D,O.D, free length, solid lenght and Wire dia.
I can calculate the pitch value. but I want to model a spring applying no. of turns not the pitch value.
Help me out...
Do let me know how to model a spring defining no. of turns. in pro/engineer.
Do anyone know how to model a helical spring defining no. of coils(turns)???
Model the spring Using VSS , then you can deifine it by the numbers of coils
I have posted in several threads about the method. Search "spring" here on the forum and you will probably find it. if not, please let me know.
//Tobias
As to my knowledge you cant do that without using relations.
Write a relation that calculates the pitch based on the length of the springand aparameter defined asno of coils.
Thank u tobbo and ankarl..
Wil try and let you know..
Adding a parameter to define the number of coils is only
temporary. When one changes the number of coils in the
parameter field, the Pitch does not change.
e.g. Let us say I define two parameters...
Length (Free length) and no_coils (for number of coils).
While in sketch mode, let us say I set a relation for the
sweep profile sd0 = length (assuming the sketch parameter
value for sweep profile is sd0)
and when asked for Pitch, I type Length/no_coils. The
program correctly calculates the values and sets the
pitch to a CONSTANT calculated. I say CONSTANT since, on
changing the value for number of coils, the pitch does
not change.
Edited by: SRINIVASANIYER1
SRINIVASANIYER1 , please upload a part that does what you say, it
Tobbo I tried VSS for spring.
I got the helical spring but what should i do for modelling a conical spring??
Im a beginner..so im trying it all the way possible.
And your post are helping me a lot.
Do let me know how to model a conical spring with VSS.
Vinom
SRINIVASANIYER1, Yes it will help me.. if you upload.
Vinom
well , now it
ok. here is a zip file with both a screen shot of the relation for pitch and the final part. I have SUPRESSED the helical sweep to reduce the file size. You may resume the same.
2011-11-14_223756_helical_Spring.zip
@Tobias: Thanks for the part. It gave new insights into
other possible methods.
Here is another method of modeling a Conical Spring using
the Helical Sweep command.
<a target="_blank" href="uploads/SRINIVASANIYER1/2011-11-
<br / target="_blank">15_033538_helical_spring.prt.zip">2011-11-
15_033538_helical_spring.prt.zip</a>
