Andy.C
- May 17, 2019
- 1
hi,i am needing to record the heat transfer through a penetration hole in an insulation panel. Hot side will be around 350°C / cold side ambient around 30°C. Hole diameters between 5-30mm, some penetrations will have structures through them.
what would be the best way to mease the heat flux? as the sensors i currently use need to have a solid contact with a surface, and i can not just suspend these over the hole.
is it possible to use thermocouples and calculate somehow? or are there any better methods?
