Headed studs in an existing composite floor system
hawkaz
415
Anyone know of a good method of confirming headed stud spacings in an existing composite floor? No plans are available
Thanks in advance
Scanning the concrete with the right equipment and a competent operator should be able to tell you the spacing. Talk to a local concrete scanner/investigation crowd.
If the beam is unpainted (or even primed and studs were welded on site), you may be able to tell by seeing any evidence of welding heat from below?
