Headed anchor studs in Profis
Prestressed Guy
For years I have used Profis to design steel embed plates with headed anchor studs but in the most recent update I cannot find this option. Did they drop this function or am I just going blind?
I typically like to use the same software to design both my post installed and cast in place anchors so that there is the need for the reviewer to only figure out one printout format. I typically spec Hilte mechanical and chemical anchors but if I need to go to Strong tie for my headed anchors, I will switch my spec to Strong tie mechanical and chemical anchors.
That function still appears on the Profis Engineering site on my end.
Are you still using the desktop app version of Profis?
Not sure why they'd remove headed anchor studs, but I'd recommend shifting over to their browser based system if you are starting to have issues with the app. They told me that app was being abandoned years ago.
