Hatches not plotting
  • Thread starter Thread starter Mony
  • Start date Start date
M
Mony
Guest
Hi all, hopefully this simple problem has a solution! I am trying to plot a dwg with a customized .ctb plot style. Problem is that one particular dwg's hatches do not show up when plotted although other dwg's that have hatches WILL show up using the same .ctb file! The outlines are there but no fill inside. Anyone? Thanks!
Check this link: Autodesk Discussion Group you may find a solution.
