I need to hang a 36" STD steel pipe, water-filled. Ideally I would like to use a single threaded rod at each support. In the past, I have seen hangers where a steel plate was welded to the pipe along the length. Then a large-diameter threaded rod was connected to a hole in the plate by a trapeze-like assembly. Is this a generally accepted method? If so, is there a standard assembly detail for this method (MSS #)? Or is each one a custom design?
