Gpost next tool call up
  • Thread starter Thread starter LMACHINE
  • Start date Start date
L
LMACHINE
Guest
I need some help with the placement of the next tool call up that is output to the nc code using gpost.
Currently my code is output with the next tool call up just before the tool change.
Example:
M1
T2
M6
N200(BORING ENDMILL)
What I am looking for is to place it after the previouse tool change.
Example:
T1
M6
M1
N100(FACEMILL)
G0G90G54X1.Y1.S3000M3
G43Z1.0H1M8T2
M98P1000
G91G28Z0
M1
M6
M1
Mike
What do you understand by this?
You have:
T1
M6
M1
T2
M6
M1
You mean:
M6
M1
T1
M1
M6
M1
T2
Correct?
Sorry
In the first example I left out the initial tool call because it's placement is fine and I was only trying to demonstrate the next tool call relative to the M6.
M1
T1
M6
N100(FACEMILL)
G43Z1.0H1M8
M98P1000
G91G28Z0
M1
T2
M6
Since then I have improved it some and my code is like the next example.
M1
T1
M6
T2
N100(FACEMILL)
G43Z1.0H1M8
M98P1000
G91G28Z0
M1
M6
T3
The guys on the floor would still prefer the next tool call in the same line with the next Z approach but this will do for now.
Try :
In G-Post window: Machine codes > Tool chenge Seq. > [X] Output next tool preselect with tool chenge
