Global dimension set
  • Thread starter Thread starter barkry
  • Start date Start date
B
barkry
Guest
Hello.
Could you tell me how to set different then standard global settings of dimensions? For example I want to use font size 5 mm for all dimensions in a drafting. I don’t want to change dimensions of fonts after I add a dimension.
Best,
Here's a link to the COE forum, with instructions for setting the default standard to inches. I think you can set the default font and size the same way.
dimensions in inches > Active Discussions > COE
