Kevin Batalha
Good day all,
I was wondering if someone was able to help / guide me in calculating the hoop stress of a thin-walled steel liner that is REINFORCED with a glass fiber material:
We are currently in the midst of performing a feasibility study for high-pressure piping being reinforced with a high tensile strength glass fiber material (E-glass, S-glass etc...). The objective is to achieve an optimal balance between the amount of steel pipe thickness and glass fiber reinforcement thickness. The main idea is to reduce weight, and overall cost of steel. This design will not yield for high volume manufacturing.
- High pressure (internal) for this application is 7,500 PSI.
- Atmospheric Pressure on the outside of the reinforced pipe.
- The inside diameter of the finished pipe will be approximately 4.0 inches.
- Since we want to minimize material, we are going to use a high alloy steel (AISI 4140 HTSR). The amount of piping should not influence the overall cost of the design.
- As a fiber reinforcing material, we are looking at 2:
The above listed above are our constraints for the time being.
Now, for an internal pressure of 7,500 PSI, I would like to accurately determine the maximum HOOP STRESS seen by the steel pipe with the reinforcement included. What we do know, is that the fiber reinforcement will only contribute to load sharing when the steel pipe expands due to the internal working pressure.
Question:
I've done some general calculations below, but I believe it may be more complicated...
Steel Pipe Hoop Stress WITHOUT reinforcement (assuming a thin-walled pressure vessel):
Pi = Working Pressure (psi) ; ri = Steel pipe Inside Radius (in) ; ts = Steel Pipe Thickness ; σh = Hoop Stress
Since the reinforced fiber material will only see stresses due to the elongation of the steel, I am assuming that the elongation in both materials are equal to determine my hoop stress :
ε = Strain ; Δr = change in radius due to elongation ; rglass = mean radius of glass ; rsteel = mean radius of steel
Solving for the hoop stress of the glass material then gives me:
To recap:
The Dilemmas:
Any help on this would be greatly appreciated!
Kevin Batalha
AISI 4140 HTSR: UTS = 150,000 PSI ; Sy = 130,000 PSI ; E = 30,000,000 PSI
E-Glass: UTS = 282,000 PSI ; E = 10,442,700 PSI ; Density = 162 lb/ft3
S-Glass: UTS = 681,700 PSI ; E = 12,473,200 PSI ; Density = 155 lb/ft3
Question:
- Is there a relationship that I can use between the two materials that would allow me to determine how I much stress the steel liner is reduced to once the reinforcement is added?
---------------------------------------I've done some general calculations below, but I believe it may be more complicated...
σh = Pi * ri / ts -------- Since all variables on the right are given, I am easily able to determine the un-reinforced hoop stress of the steel pipe.
ε = Δr / r = σh / E --------> Δr = (σh * r / E)steel = (σh * r / E)glass
σh glass = (Eglass / Esteel) * (rsteel / rglass)* σh steel
To recap:
- I solved for the hoop stress of the steel liner assuming it has no reinforcement.
- Using the stress-strain relationship, I determined the hoop stress of the reinforced material assuming that both the steel and glass fiber reinforcement stretch the same amount.
The Dilemmas:
- I am quite certain that it would not be accurate for me to determine the hoop stress based on the steel elongating at its maximum amount. The thickness of the fiber reinforcement will take up some of that elongation, and so I feel that this approach would be way to conservative. Given that the reinforcement will take up the elongation, it will also take up some of the hoop stress seen by the steel that I calculated above.
- Is there a way that I can solve for the reduced steel hoop stress given the information above???
Kevin Batalha
