Get Selected Hybridshape name
NaWin55
98
Hi
I have a user form here i want to display the selected hybridshape name which is present in any geometrical set
i tried this code but it is showing like this
Selection_RSur:(Face:(Brp:(GSMSymmetry.1;(Brp:(GSMSweep.1;(Brp:(GSMExtrude.6;2:(Brp:(GSMLine.84)));Brp:(GSMExtrude.6;0:(Brp:(GSMLine.84)))))));None:();Cf12:());EdgeFillet.1_ResultOUT;Z0;G9061)
but if select a FILL it should Fill.1 or if i select a EdgeFillet it should show Edgefillet.1 like that
here is the code
Option Explicit
Dim oDoc As Document
Dim oPartDoc As PartDocument
Dim oPart As Part
Dim osel As Selection
Dim oSel2 As Object
Private Sub UserForm_Initialize()
Set oDoc = CATIA.ActiveDocument
Set oPartDoc = CATIA.ActiveDocument
Set oPart = oPartDoc.Part
End Sub
Private Sub SelectFeature_Click()
Set osel = CATIA.ActiveDocument.Selection
Set oSel2 = osel
osel.Clear
Dim varFilter(0) As Variant
varFilter(0) = "AnyObject"
Dim status As String
status = oSel2.SelectElement2(varFilter, "select Face", False)
If (status = "Cancel") Then
MsgBox "user Cancelled"
Else
SurText.Text = oSel2.Item(1).Value.Name
End If
End Sub
In this image i selected surface from geometry not from model tree
how to solve this
thanks
VBA:
Dim obj as Object: set obj = CATIA.ActiveDocument.Selectioj.Item(1).Value
If obj is Reference then
Set obj = obj.Parent
End if
Msgbox obj.Name
By the way, SelectElement... documentation clearly states that you should NOT call it from a userform.
