Get Activate Model in Assembly [Weblink]
  • Thread starter Thread starter ElliottW
  • Start date Start date
E
ElliottW
Guest
Hi, all
I have trying to assemble components into subassembly which had been activated,
but just can't find any way to get the Activate subassembly model.
model.currentmodel only can get root assembly.
<A name=FEAT_ACTIVE>FEAT_ACTIVE</A>in pfcFeatureStatus will get all component showing on the current window.
Is it possible to dothat in weblink?
Any advisewill be fully appreciate
Hello ElliottW,
Do you able to get the solution for this? I too trying for the same.Can you plz share me do you get any work around methode to get the active model object from the given assembly?
With regards,
Kishore V
