geometric tolerances in drawing
  • Thread starter Thread starter sbpanda
  • Start date Start date
As far as I know you have to choose in "Geometric Tolerance" menu under option "Placement: To Be Placed" an option "Dimension" and just to pick a dimension. That is one way but there are other ways also, so it would be better if you could specify what you want to do exactly.
Click on Dimension, right click, choose properties. In this properties dialog box there are several options.
1. Symetrical, nominal, plus or minus, etc.
2.general, none, etc.
I normally have symetrical and none st. This will allow me to change dimension and tolerance.
Apaxcad
Hi dear denisvragolan & Apaxcad
I need a breif understanding abt standard formats, how people arehandling the geometric tolerances, if u can give some helpfull links.
thanks
sudhanshu@desmania.com
Hello sbpanda,
I hope this link can help
http://www.roymech.co.uk/Useful_Tables/Drawing/draw_geom.h tml
What do you need help with? Do you need to know how to put Gtols in the model / detail? Do you just want to put a Gtol to a dimension? More information is needed to answer your question correctly.
First set your datums (If required for your geotol type). An easy way to do this is to right click on the datum (or axis) and select properties. This can be done in part/assy mode or dwg mode. Personally, I prefer to do it in dwg. mode.
Then in dwg mode, select the geotol icon or go to Insert/geometric tolerance.
There are many possibilities here but the menus are self explanatory, assuming you have a good understanding of the use of geotols.
BChapman
Edited by: brchapman
