Gear Profile Using Unigraphics
  • Thread starter Thread starter ranjith_info
  • Start date Start date
R
ranjith_info
Guest
Plz help me in modeling the gear tooth using Unigraphics
the in puts are
NORMAL PITCH 10 D.R
N2 OF TEETH. 105
NORMAL PRESSURE ANGLE 20 Deg
HELIX ANGLE & HAND SPUR
PITCH CIRCLE DIA. 10.500
INVOLUTE BASE CIRCLE DIA. 9.8668
ADDENDUM. 0.072
WHOLE DEPTH. 0.225
ACTUA; BACKLASH. .006/.008
CORRECTION. -0.025
CHECK DISTANCE OVER 5 TEETH 3.5198/3.5188
ROOT DIA. 10.194
FORM OF TEETH INVOLUTE
CLIPER. HEIGHT FROM NORMAL% .050
SETTINGS THICKNESS .1177/.1167
MAX. ERROR IN TOOTH TO TOOTH PITCH ACCURACY 0.0002
MAX. ECCENTRICITY OF PITCH CIRCLE 0.001
TOOTH HEAD EDGES ROUNDBED 0.005
TOOTH FACE EDGES ROUNDBED 0.01
R.P.M 2171 3/7
CENTR DISTANCE 7.153/7.147
FINISH OF TEETH :-
Which version of NX are you currently using?
Unigraphics NX3
That's quite an amount of information to work with. I guess you may need to pay someone to do it for you rather than asking for help this way. This is a forum, not an extended helpdesk.
Gear profile using NX
If your licence allows you to execute grip routines there is one available called gear_3d that can be used to generate 3D gears. You could try asking your local NX support office, they may be able to help you with a copy.
