engr2GW
Petroleum
- Nov 7, 2010
- 308
sometimes during gas hydraulic calculations, one may meet the recommended velocity margin, but the pressure drop may be a bit on the high side, other time, one may get the pressure drop per 100feet just right, but the velocity may be lower than typical recommendations.
Because the source and destination pressure can not change, it seems like if the dp/100' if achieved given the P1 and P2 and length, then we have to make it work using the available velocity? especially if no other pipe size will give us that velocity with the given conditions?
Example: A pipe size at the given source and delivery pressure gives me 0.5psi/100' which is at the lower end of the dp range, given the MCFD. But the velocity is half the minimum required velocity (i.e., 25ft/s instead of 45 or 60 ft/s). Is this one of those cases where we use periodic pigging operation to help with the velocity (I am assuming that the velocity is to keep the pipe from collecting liquid dropout at the bottom of the pipe?)
THANKS FOR YOUR HELP
As much as possible, do it right the first time...
