engr2GW
Petroleum
- Nov 7, 2010
- 308
In liquid flow (probably because of incompressibility) when flow in a pipe that goes, say, from 2" to 1" and back to 2". The Q=VA ensures that the flow rate is the same in each segment. Is it fair to say that the flow max is equal to the max capacity flow of the smallest diameter?
If this is true, does it apply to gas?: I have a 150' 2" pipe that changes to 1" for just about 3' and back to 2" for another 100'. At a supply pressure of say, 100 PSIG, does the 1" segment limit max flow? I also noticed that pressure after the 1" segment dropped to about 90PSIG
Thanks for any input, answer, experience, or pointer as to how I can figure.
As much as possible, do it right the first time...
